Amada - Edge and Approach
Can anyone help me solve the pazzle, Edge and Approach data
When does each come into action?
Amada - Edge and ApproachAmada - Edge and Approach(OP)
When does each come into action? Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Amada - Edge and Approach
What about fine edge?
Approach Data is to slow down after the pierce and stabilize the cut.
Edge Data is used to pulse on corners specially while cutting thick plates with large diameter nozzles. This prevents the burning on corners by using low power, frequency and duty, as well as low speed.
Both Approach and Edge Data are mainly used in thicker materials.
Hope this helps
fine edge is tricky to work out as it did not seem to be much information in the manuals.
The setting are in the fine edge data page
push custom button
then left arrow soft button
then parameter
then page down (seems like amada wanted to hide it)
you can use 901 to 910
Turn it on in the the cutting data page under pulse type column. (you can select from 901 to 910)
when you are cutting you can see that the power, freq & duty are changing when contouring.
I have a part that makes almost a 180* turn (picture the outline of a U)and always leaves my operator grinding out the burrs. you can see a definite hot spot on each corner. we are cutting 1/2" mild steel with the following condition: 38IPM, 3000w, 700hz, 75%duty. GP 0.07 oxygen. using 1.4 double nozzle.
what would you say would be a good edge data to try, I can get anything to work out for me.
