ETABS - MATLAB API
ETABS - MATLAB API
Hello!
I'm starting using the API MATLAB-ETABS, and I found an error which I hope you can help me to solve, next you'll find the code of the example:
If you run that code, in your command windows will appear:
No method 'JointReact' with matching signature found for class
'Interface.ETABS_2015_Application_Programming_Interface__API_.cAnalysisResults'.
I hope you can help me with it, thanks!
clc, clear all, close all
NumberResults = NaN;
Obj = cellstr(' ');
Elm = cellstr(' ');
LoadCase = cellstr(' ');
StepType= cellstr(' ');
StepNum=NaN;
F1=zeros(1,1,'double');
F2=zeros(1,1,'double');
F3=zeros(1,1,'double');
M1=zeros(1,1,'double');
M2=zeros(1,1,'double');
M3=zeros(1,1,'double');
% 'create ETABS object
EtabsObject = actxserver('CSI.ETABS.API.ETABSObject')
% 'start ETABS application
ret = EtabsObject.ApplicationStart()
% 'create SapModel object
SapModel = EtabsObject.SapModel
% 'initialize model
ret = SapModel.InitializeNewModel()
% 'create steel deck template model
ret = SapModel.File.NewSteelDeck(4,12,12,4,4,24,24)
% 'run analysis
System.IO.Directory.CreateDirectory('c:\CSI_API_temp')
ret = SapModel.File.Save('C:\CSI_API_temp\example.edb')
ret = SapModel.Analyze.RunAnalysis
% 'deselect all cases and combos
ret = SapModel.Results.Setup.DeselectAllCasesAndCombosForOutput
% 'set case selected for output
ret = SapModel.Results.Setup.SetCaseSelectedForOutput('DEAD')
% 'get point displacements
ret = SapModel.Results.JointReact('1',1,NumberResults, Obj, Elm, LoadCase, StepType, StepNum, F1, F2, F3, M1, M2, M3)
% 'close ETABS
EtabsObject.ApplicationExit(1)
% 'clean up variables
clearvars SapModel EtabsObject
Obj = cellstr(' ');
Elm = cellstr(' ');
StepNum=NaN;
% 'initialize model
% 'run analysis
% 'close ETABS
