Corrosion in Aluminum Pontoon Pipe 3004 grade
Hi
I have 1 question for you guys.
We have encountered pitting corrosion in the pontoon pipes(Al 3004) of a internal floating roof of the carbon steel tank.
The steel tank was hydro tested and half of the pontoon pipes are corroded. Initial thoughts are that it occurred due to the galvanic corrosion between Al and carbon steel tank in which the tank and Al are connected through a water electrolyte which has chloride content.
Any other reason of you have encountered similar failures.
Thanks in advance
Thanks in advance
RE: Corrosion in Aluminum Pontoon Pipe 3004 grade
