Reinforcement Detailing for Opening in Flat Slab and Beam
Dear All,
I face a difficulty in doing the reinforcement details for the flat slab with opening. The opening that the Architect wants to put is for a scupper drain which have a width of 150 (on plan) and a depth of approximately 100mm (the drain is just to connect to the oil interceptor).
I know I did read somewhere that the opening should not be too near to the column head/drop panel because of shear or something in the flat slab. So I was thinking to suggest to the Architect to move the drain away from the stump area. However my colleague suggested the detail to be as per attached. Oh yeah, we designed the slab as flat slab.
The other thing is about the opening in the beam. How would the detailing be like for the reinforcement around the opening if the scupper drain is located 600mm away from the support of the beam, and at the suppport there is a moment and if I put an opening there, my top reinforcement of them beam will be disconnected. Please advice.
Would appreciate you suggestions and thought.
Thank you.
Thank you.
a trainee who wants to learn and learn
RE: Reinforcement Detailing for Opening in Flat Slab and Beam
As to an opening in a beam of the same size, you can't just "disconnect" the reinforcement. You would have to provide bars to ensure the continuity of the flexural strength.
As noted above, trying to put openings in beams is problematic (translation: a bad idea).
and Archie264, a great link there, thanks for sharing. (:
