Surface defect on API 5L pipe 20"
I would get the recommendation of you in this uncommon case for we.
During the laying of a pipeline under construction, was found in one of the pipes, a origin deep surface defect (hole)not seen at its reception.
The hole has a conical shape, whith external diameter of 13mm and is 13mm in depth.
The pipe specification is API 5L Gr B; size 20"; WT 0.812" (20.6mm); anticorrossion coating FBE, plus concrete 2.5".
Pressure test by design 20.65bar (300psi).
The pipeline was welded in 500mtrs segments at land (onshore)before being pulled out to sea.
Now we have strong suspicions that other pipes of the same lot number may have similar defects.
So, i´d like to know which method may be recommended to detect other possible similar defects masked by the layer of concrete.
we are considering a higher pressure test (1920psi) to uncover impending failure but we are not sure about.
See attachment
What do you think about it...?
Thanks in advance
See attachment
Thanks in advance
RE: Surface defect on API 5L pipe 20"
Well, if you could see the attached image, the gap is partially coated with FBE in its internal cavity, ie that already existed in this pipe before being coated whith FBE.
I'd run an intelligent pig and start a claim against the mill to pay for that and any repairs.
I´m agree that the pressure test is risky, but, do you know any especific intrnal smart tool for detect defects in the body of the pipe..?
In general, smart pigs may be used to detect stress corrosion cracking, general and pitting corrosion.
In specific: gouges, dents, pit corrosion, anomalous weld seams, longitudinal cracks, longitudinal grooves, and general corrosion are all detectable.
Contact:
http://www.dacon-inspection.com/services/pipeline-...
http://www.pipelineandgasjournal.com/td-williamson...
http://www.enduropls.com/products/inspection/dfl.h...
http://www.applusrtd.us/en/service/PIT_(Pipeline_I...
You need to find someone who is to fight your corner against the mill which could go to court, so preserve all samples and take lots of photos and records.
I can't quite understand why you have such a large wall thickness for the design pressure and in the end this might be your savior.
While it's not great, the wall thickness you have at a DF of 0.72 gives you 2000 psi design pressure. It would seem your current design pressure is about 200 to 250?
Hence do a fitness for purpose assessment using one of the known tools (31G) and look at it as a deep corrosion pit of 65% wall loss.
I suspect at 250psi it'll pass without a problem at that sort of size.
I don't know what your service is, but maybe think about lining it - structurally the pipe isn't affected, but clearly might spring a leak at some point. Running an intelligent pig and choose the right one for this type of defect - an MFL pig might pick up defects like this better even if they are not craters yet - then make your decisions.
This type of holes on the pipe are created mainly by external machine work, excavators or air tools if the pipe was laying in the ground covered.
We are looking for a inspection company that can carry out this evaluation with smart tools like recommended per you.
The desing pressure is 240psi, service Fuel Oil.
The pipe is longitudinal seam. I'm almost convinced that´s defect in the original strip. But I do not have knowledge on material defects.
The hole was detected during the cleaning with power tool before the examination of the weld by UT. It was filled with foreign material and covered with FBE.
