Catia V5 - Image Quality
I'm using Catia V5, and I need to save four objects, each one with diferent heights.
I've saved using Image->Capture->Pixel Mode, and save jpeg high quality. I've tried another formats but the result is always the same: image is pixelated.
What process should I use to have image with good quality, as I see in the stage?
Thanks in advance!
Luís
Thanks in advance!
Luís
RE: Catia V5 - Image Quality
You'll have to play around with the settings in Tools > Image > Capture
Have you played around with the rendering quality setting?
You might try to capture a vector image.
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
I played with the setting but with no results, even the semantic level to discretized.
Another process that I tried was the Photo Studio. The quality is very good...I will see if I can work with that.
Thanks!
Luís
