Turning Translucency on, but wont turn off
NX 10
In my top level assembly, I selected "Edit Object Display" and selected several parts, slid the "Translucency" bar over
to 50 percent, and saved the model. Came back to the model later, decided I did not want the parts translucent, now it won't let me change
the Translucency back to zero. I slide the bar over, but when I exit out of Edit Object Display, it still stays 50% translucent.
WTF????
Suggestions?
Steve
RE: Turning Translucency on, but wont turn off
It works fine for me using NX 10.0.3.5.
Make sure that both time (and in particular when you're trying to remove the translucency), when selecting in the context of the Assembly, make sure that you're actually selecting the Components and NOT the Solid Bodies.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
Hi Steve,
Try sliding the bar to max, then back to zero.
Andy.
