Transferring image to surfaces
I have been asked by a customer to add their logo to a panel is their some format of graphics file that I can use which will provide an edge curve so that I can use these to create the surface without having to redraw?
Thanks.
RE: Transferring image to surfaces
@markwindsurf
I think the Developed Shapes license allows you to transfer 2D elements to a 3D curve. It also contains features to fold/unfold a surface.
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
this is a good way to use picture as a texture. used that several timespc2.
if a logo not too complex you can convert it to dxf and then workaround with that.
Thanks for your comments. Unfortunately the logo is a very complex flowery script, so impractical to trace. JeniaL how would I translate the image to a DXF?
could you ask the client to give you vector file logo ?
Eric N.
google for scan2cad they have a trial. with a complex picture converting won't help.. post a logo i'll try to help
