Crane Impact Loads
Crane Impact Loads
In ASCE 07, Section 4.9, the code reads that the crane impact loads are to be applied to design of runway beams, including connection and support brackets. If we have a crane which is supported from the truss panel point, do we have to design the entire truss members (top chord, bottom chord, verticals and diagonals) for the impact load? Code just says the runway beam to be designed for the impact load. So can we design the truss just for the straight crane loads with no impact.
RE: Crane Impact Loads
Provide a complete load path for the crane loads with impact to the end of the structural system
-or-
Justify that once the load has reached certain elements of your truss, that any dynamic/impact effects have been attenuated by the flexibility of the structure (the deflections required should be within acceptable limits).
Which of the two is easier depends on your truss arrangement.
Professional and Structural Engineer (ME, NH)
American Concrete Industries
www.americanconcrete.com
Dave
Thaidavid
