Steel Column with block wall and Wind Load
i am designing a PEB building which includes full height hollow block wall masonry all around does we apply the wind load on steel columns however connection between the Block wall and steel column is through brackets/Ties partially.
bay spacing is 6 m and height is 6.5 m
Regard's
Syed Ammar
Regard's
Syed Ammar
RE: Steel Column with block wall and Wind Load
Jim
I refer you to the NCMA manual for cement block and metal buildings.
Jim
