Gyroscopic Forces
Gyroscopic Forces
I am trying to calculate the force imparted on a rotor bearing when the rotor is at speed and the vehicle takes a hard turn. I can find the rotor moment of inertia and its angular momentum, but not sure how to find the force due to gyroscopic action. Most of the information I have found focuses on precession and the shape and rate of precession. Seems like there should be a fairly straightforward way to get force from momentum when you rotate the spinning rotor in some direction other than along the shaft axis.
RE: Gyroscopic Forces
m.(v - u) = F.t
where underlining indicates a vector quantity. You doubtless remember this equation from your high school physics, as "change in momentum equals impulse".
This has an exactly analogous equation for rotational motion, as "change in angular momentum equals angular impulse":
I.(V - U) = T.t
where I is the moment of rotational inertia, U & V are the before and after rotational velocities, and T is the average torque required to effect the change over the time t.
Just make sure you get the directions of the rotational vectors correct (and remember to use radians as your measure of rotational displacement).
http://www.newtontime.com/newtongyro.html
Ted
