Steam density with velocity
If I have a pipe with steam flowing in it at what I think is around 200 metres/second and I want to calculate the density of the steam do I simply use the static pressure and temperature shown on my gauges (85 Psia and 330 Deg F) and pick the appropriate specific volume from steam stables and convert it to density, or, in some way, should I account for the velocity of the flow and include something for dynamic pressure ?
I know this seems a basic question, but I don't want to miss something obvious.
Thanks in advance for any help.
RE: Steam density with velocity
Velocity is only a function of flow rate and pipe size. Also - something seems off with your estimate of 200 m/s velocity. That would be extremely high, even for superheated steam (and you only have about 15 degF superheat).
I am only questioning my own sanity because it has been stated categorically by a respected engineer in a large organisation that you pick the steam specific volume from steam tables based upon Total pressure, ie static pressure plus dynamic pressure.
From my point of view I can't quite see how you do that as it is surely a circular function.
I get that there might be an argument about compressibility affecting the result, but 85 Psia is not a high pressure and in perfect gas terms compressibility would certainly be ignored.
Agreed total energy = stream enthalpy + kinetic energy + potential energy (due to static height differential from datum).
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
