Which better bearing using brass cage or steel cage for xantathor machine
Please help me,
Shaft Tilt 7,5 deg
Speed 3, 27 and 40 rpm
Load max : 35 tones
Thank you
RE: Which better bearing using brass cage or steel cage for xantathor machine
Here is a discussion of the types of bearing cages as used in precision spindle bearings.
I'd talk to the bearing manufacturer for their recommendation.\
Google didn't do well with "Xantathor ."
What type of bearing is it? If stress in the cage structure is an issue, then alloy steel might be a better choice. Brass has poor mechanical properties.
