Mesh element + bonus script
Hallo
I am new ABAQUS user. I have problem with script in ABAQUS. I am trying to create a offset mesh (Solid layer). I am trying to couple parameter for geometry and solid layer.
for surface come this script face6Elements = f[0:1]+f[2:3]+f[4:5]+f[6:7]+f[8:9]+f[10:11]+f[12:13]+f[14:15]+\....... which depending from the geometry and the size of Mesh when i was recording it with Macro
With script when i was recording :
http://files.engineering.com/getfile.aspx?folder=0...
After i change the geometrie in script :
http://files.engineering.com/getfile.aspx?folder=9...
Script :
http://files.engineering.com/getfile.aspx?folder=b...
looks like ABAQUS has a rule to number its surface
what should i change in script , so i can select the surface that i want ( like when i was recording ) ?. Sorry for my bad english
Thank you in advance
