Megger Use on Aircraft Wiring
Anyone aware of any published guidance on using meggers (MegOhm Meters) to check aircraft wiring insulation (and connectors) on aircraft wiring?
My posts reflect my personal views and are not in any way endorsed or approved by any organization I'm professionally affiliated with.
RE: Megger Use on Aircraft Wiring
Catching up to an old post... sorry if it's too late to matter.
Does the aircraft in question have an "ESPM" or Electrical Standard Procedures Manual?
STF
Thanks, I eventually did find it in the Airbus ESPM found nothing in a Boeing SWPM though. It's under insulation testing and they call it a megohmmeter.
OK
I figured you would have found it by now.
STF
