B31.8 Elastic Bending radius
does any one know what basically is meant by elastic bending radius....?
what its significance...??
after all the calculation of elastic bending i got a value of 261.6 m for a 16 inch pipe .what does this show....?
and finally then what is the difference between the cold(24D) ,hot bending(5D) done on pipes and the elastic bending....??
RE: B31.8 Elastic Bending radius
If you bend the pipe into a curve and it won't return to straightness after you've released it, you have yielded the pipe and have made a cold bend. Cold bends are usually not very sharp bends, most pipe will need minimum radaii of 40 x diameter.
http://www.eng-tips.com/viewthread.cfm?qid=258983
Hot bends are made by heating the pipe to lower yield stresses, thus can be bent to tighter radaii.
Disadvantage of elastic bending is that if the pipe is bent elastically and held in that position forever (after construction has been completed), the elastic stresses, although less than yield stress) remain in the pipe forever. When you pressure the pipe, the pressure stresses will add to the elastic stresses, which could cause allowable stress to be exceeded when under pressure. That could require that your maximum allowable operating pressure be reduced, so the combined stresses remained below limits.
Cold and Hot bends have no remaining stress once the bending forces are released. Therefore hot and cold bends can be pressured without adding to any previous stress resulting from holding the elastic bend in place forever.
How did you get to the rather exact radios of 261.6 m?
The only think to add really is that elastic bends work fine in vertical profile, but are very hard to do horizontally so I wouldn't try.
24D cold bends at 16" diameter may be ok in terms of maximum strain, but I've never seen any. 40D is pretty much standard.
having all the pipe data (i presume u have)
first calculate the # hoop stress
then # maximum allowable stress
then # thermal stresses
now from code b31.8 we have
max bending stress= maximum allowable stress-0.3*hoop stress-thermal stresses
now to calculate the bending radius we have flexure formula
bending radius = Modulus of Elasticity*pipe Dia /2*max bending stress
i hope u got it
You need to work out which is the smallest amount "left" from the max for the bending force. Sometimes its the inside of the bend, sometimes it's the outside.
You've ended up with a radius of about 640D, which is about the lowest you want to go. 1000D is more normal and will generally pass the stress checks.
