TIG welding Titanium Grade 2 to Grade 5
I am looking to weld Titanium Grade 2 to Grade 5 with TIG.
Can someone give some guidance on the precautions to be taken and the consumable?
Thank you.
Thank you.
RE: TIG welding Titanium Grade 2 to Grade 5
https://www.millerwelds.com/resources/article-libr...
The Miller link is excellent but I think it minimizes the risks of welding the stronger gr 5 material. Welding commercially pure titanium is tough to begin with, and adding gr 5 to the mix makes it a fair bit worse still.
Therefore moltenmetal, which consumable do you recommend?
But I would check with your material producer and see what they say.
I don't weld gr5.
