One setup for a range of loading conditions
New Catia user here. I have a component which I want to perform static analysis using a number of different loading conditions. Each loading condition will be independent of the others so a series of analysis must be performed.
Can I set up one analysis with a number of different loading conditions but be able to suppress the all but the load of interest. This is to limit the meshing and restraint setup to one model.
RE: One setup for a range of loading conditions
once your first static case is define simply go in menu Insert / Static Case and defined reference for Restraints (and new for Loads)
Eric N.
So how do I switch back and forth between loading conditions? Is there a way of suppressing individual static cases?
