How to make constant length spline in different shapes so it can be used for deformable (cable) part
I have cable of 380 mm that is reused on 12 different places in assembly. How to make splines between sets of two (different for each cable instance) points but to keep splines length to be 380 mm? Distance between points in strait line is always less than 380 mm.
RE: How to make constant length spline in different shapes so it can be used for deformable (cable) part
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
I do not know if routing can provide same assembly number x12 in part list?
