Compliance with API standards
My team is building an app to help fellow materials and corrosion engineers select the right test instructions to be in compliance with API and other important standards. Can anybody share what would be useful? Maybe a test wizard that asks about your requirements and points you to the appropriate API or ASTM standard? How do you go about it now without going through PDFs hundreds of pages long? Any help greatly appreciated. You might want to be a beta tester when it's ready. Thanks!!
RE: Compliance with API standards
Over the years various oil companies (Shell) have sunk 10's of millions of dollars into systems that take system variables, calculate what corrosion will occur, and then figure out the impact on materials.
It is 'simply' a merging of chemical engineering, corrosion science, material engineering, and petroleum science.
