Surface Finish for Light Pipe Diffused Exit surface??
Before someone tries to moderate and shut this thread down like another one that was asking the same question, which was never answered, I also would like to know what a good finish is for light pipe diffused exit surface.
I read all the link on the other thread and didn't find a specific answer to the question. It looks like the polished part of the body would do well with a SPI-A2 finish, but need to find the diffuser exit surface finish.
Try worrying less about moderating and sending people off to areas with vague answers than letting them discuss and share information they are having a hard time finding. If I could find it I wouldn't be here asking.
RE: Surface Finish for Light Pipe Diffused Exit surface??
I'm not sure why you are so upset; but if there are no replies to a thread in 6 months, the thread is automatically closed. Perhaps this is what happened to the other thread.
Anyway, if you are only looking to diffuse the light, pretty much any light (no pun intended) texture will do. If you are looking to achieve a certain effect, perhaps small concentric ribs or a faceted surface would do better.
Thanks, am not upset, but the first response on the other thread was someone moderating them. Am looking for someone who has actually designed a light pipe to give me some guidance.
I've tried milling ribs in an acrylic prototype, but it didn't work very well; you'd need to go to very fine geometry.
... which is more easily achieved with sandpaper.
... which you pretty much have to do by hand, because fast-moving sandpaper just melts plastic.
Separately, I tried refinishing plastic headlamp lenses with a $25 3M kit and a battery powered drill.
The drill was slow enough that the plastic didn't melt.
The first part of the process involves a disc that I think is about 600 grit, and fairly special, in that it didn't clog easily, even when used dry as instructed.
When that was done, the lens appeared to be opaque white; i.e., the surface was very diffuse.
(The second step involved a much finer grit and water, and the end result was spectacular; no other headlamp refinish kit I've tried worked nearly as fast or as well as the 3M kit.)
Mike Halloran
Pembroke Pines, FL, USA
If it's the thread from 2008, the OP was told that double-posting wasn't allowed (new posters tend to spam multiple forums to get their question answered). Try not to admonish the folks here for things you think they might do to you, particularly if they haven't done it... it sets a poor tone for the following discussion.
If you want a diffuse surface, I would expect an A2 to be too polished... I'd shoot for something closer to a B1/B2.
Dan - Owner
http://www.Hi-TecDesigns.com
You would be best off getting some acrylic rod and simply experimenting with different finishes.
