Fault current
Fault current
Good day Folks,
Can anyone tell me the difference between Asymmetrical and symmetrical RMS fault current and how to determine its values for a ring main unit
RE: Fault current
What is a ring main unit? Is it part of a generator brush works, or is it a part of a ring bus?
RE: Fault current
An RMU is a piece of distribution switchgear comprising two HV disconnectors and an HV switch-fuse or breaker in one piece of apparatus. In the UK they're commonplace at the bottom end of the distribution chain, typically serving relatively small loads from the 11kV network. Older ones were often oil-filled. Here's an example of a modern SF6 one:
http://hemhub.com/wp-content/uploads/2015/08/ELE09...
RE: Fault current
RE: Fault current
