Is there a way to generate a list of all of the files you have checked out in Teamcenter/NX?
No matter how careful I seem to be about checking files back in when I am done, inevitably I always get someone telling me I somehow have a file checked out. Is there a command or something I can run every so often that gives me a list of files checked out for either just my teamcenter ID? A way to do a site wide list of all the checked out files and who has them checked out would also be great so I cam hopefully start to crack down on people leaving things checked out. I am using TC10 to be exact.
RE: Is there a way to generate a list of all of the files you have checked out in Teamcenter/NX?
Go do search a general search pull down then go to more. This should be at the bottom of the pull down. Under system defined searches find Checked-out Objects. Then you can do a search on this.
-Dave
NX 9, Teamcenter 10
I don't recall which preference that was.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX8.5.3 / TC9.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
