NX 8.5 - Addition of new Forms
I need to create one customized dialog box form using Journal as VB, which will take the inputs for title block information and part attributes like (DWG NO, title,FGN NO, DWG Description, Material , Specification info etc.) all together as the procedure for this provided in NX is too repetitive.?
Can anyone have the codes for this so that i can run the codes and the form will take all the inputs together???
