Subgrade Modulus for a Pipeline
The project is for a pressurized pipeline that will go between 5 ft to 25 ft below ground surface (depending if they do HDD or trenching). The pipeline extends for about 6 miles, so there is a large variation between materials along the plan view.
The hydraulic/civil engineer want subgrade modulus of the soil along the alignment. They want the subgrade modulus to possibly allow a cheaper/weaker pipe along sections with a high subgrade modulus. I can provide them these values based on correlations and soil type (as you would for a mat foundation) but I've never used these correlations for this application. The pipe will apply stresses both vertically and horizontally on the soil so I will have to provide a subgrade modulus for both directions.
Can anyone provide insight to this? Has anyone come across this before? Any publications you can direct me to?
RE: Subgrade Modulus for a Pipeline
Since you are able to provide the requested information, if you do so, and then follow-up with the hydraulic/civil engineer, you may get the answer to your questions from that engineer.
www.SlideRuleEra.net
www.VacuumTubeEra.net
Richard A. Cornelius, P.E.
WWW.amlinereast.com
