Create datum plane based on Bounding Box coordinates
Is it possible to create a datum plane based on bounding box coordinates? I need the plane to encompass a certain area in the assembly for visual purposes.
RE: Create datum plane based on Bounding Box coordinates
What version of NX are you running?
If you're running NX 10.0 there's a new option in the Clip/Edit Section function where you can define a 'Box' type View Section by selecting an object of interest while in the Edit Section function, based on the bounding box of the selected object. Once there, you can define a Datum Plane on as many of the six sides of the 'box' as you wish.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
