Is Iron Man suit possible?
I know what you are thinking; this question sounds absolutely riduclous right? Well maybe it is; but I thought the best place to enquire about possible techical concepts would be a forum for engineers.
Think about the things engineers have designed and discovered thus far. Material sciences has come a long way.
If this HAD to be done, could it be?
RE: Is Iron Man suit possible?
Even for just the amplified mechanical motion of the joints required Tony Stark's power source, which doesn't and won't exist in this universe. The HULC suit might one day get a decent battery, but that's not happening anytime soon.
All that's missing from HULC is a Mr. Fusion. The supposed solar power approach is bogus.
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
What's funny is when you referred to HULC suit I thought you were referring to Iron Mans Hulk suit.
I am just curious though, what type of alloy do you think would have to be used that would be light enough to get off the ground but still take a beating? I am not sure if any current air craft alloy could do the job, but I am only guessing.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
Go to Machine Design's website and read up on exoskeletons. There has been some development of those, to increase human load capacity, and to help people with spinal injuries.
Read up on Troy Hurtubise and his bear proof armor. This did not fly. Maybe he did not annoy a big enough bear!
When you want to armor something that flies, you need to make compromises. The reasoning behind the A10 was that half the aircraft shot down in Vietnam were victims of small arms fire. Comic strip writers are not limited this way.
JHG
JHG
