High teperature rotary seal
Hi engineers,
I am looking for a rotary seal to prevent hot gas from exiting the gas pass through the clearance of the stator vanes. The vanes can rotate (they are actually nozzle guided vanes). The working temperature is 500 C and the pressure difference is 5 bar. the rotation speed is less than 20 RPM. The shaft diameter is about 2 cm.
most of the commercial seals have max operating temperature of 300 C. Please tell me if there are some commercial high temperature seals and their suppliers.
Thank you in advance,
RE: High teperature rotary seal
