Nasty Lines showing up In drafting after using routing application
Hi all,
I have created a model and have used the mechanical routing application to create the appropriate pipe work.
Trouble is, when I go to the drafting application I am getting loads of dashed lines and arrows which I suppose are depicting the flow of the pipe work.
I dont want these in my drawing, just the pipes, how can I get rid of them- they seem to be unselectable!
Help!
RE: Nasty Lines showing up In drafting after using routing application
Havent figured out why it was doing it, but I deleted the drawing file and started again and now its ok.
