Weld joint preparation
What is the standard procedure for joint preparation for tee joint if plate thickness is 1/2 inch,bevel necessary or not.
RE: Weld joint preparation
With all due respect your comment is misleading.
It is either single V or single bevel - it cannot be both.
If it is a Tee joint (and full penetration required) it can be a single bevel or double bevel,
Cheers,
DD
I did mean to say a single bevel.
For a 1/2" thickness, beveling is required for full penetration.
