Tie Beam Bracing System (Steel Structure)
I am designing a steel structure the issue is that i cannot provide the wall bracing (even portal bracing)due to some restrictions , so i am providing tie beam , column web to column web (both Fixed end support), My question is that does this tie beam will work as bracing member , however the drifting is under allowable after providing the tie beam.
please see the attachment for more clarification
Thanks in Advance
Regard's
Syed Ammar
Thanks in Advance
Regard's
Syed Ammar
RE: Tie Beam Bracing System (Steel Structure)
BA
If I use SHS Columns instead of I section, what you think I can get more resistance in both axis against drifting in this case???
However I know to design of moment connection will be difficult between I beam and SHS column.
