NX laptop workstation
It will work with NX7.5, 3D modelling, drawing, nastran FEA. Complexity is around like 3 times engine oil vane pump.
I am looking for recommendation of the best mobile workstation.
I do not like security card that can be lost, and the machine will not be in USA.
Is I7 or Xeon cpu significantly faster than i5?
The screen 15 in size is max size I want
Go with 8 or 16 GB memory
Is Dell the best choice.
If yes go with 157000 or 6800 workstation. Or how about gaming workstation.
Please do not assume anything
RE: NX laptop workstation
Dell M6800
17.3 inch UltraSharp FHD(1920x1080) Wide View Anti-Glare LED-backlit with Premium Panel Guarantee
Intel Core i7-4910MQ(Quad Core 2.90GHz, 3.90GHz Turbo, 8MB 47W, w/HD Graphics 4600)
NVIDIA Quadro K4100M w/4GB GDDR5
32GB (4x8GB) 1600MHz DDR3L
256GB Solid State Drive Full Mini Card
1TB 2.5inch SATA (5,400 Rpm) Hard Drive
Win 7 Pro.
At least 16 GB RAM. 32 if you can.
Mark Rief
NX CAM Customer Success
Siemens PLM Software
The laptop ThreeCircle describes is the top choice.
Probably there is a similar machine from HP.
That machine is also a Siemens-certified one , the reason you should use a certified computer is that if you have trouble with the graphics on a certified computer, GTAC will try help you .
If you have graphics-trouble with a non certified computer, GTAC will say "Try a different graphics driver, we cannot help you further."
Tomas
win 7/64
16 GB memo DDR4 2133 MHz
NVidia Quadro M2000M - 4GB GDDR5
cpu: i7-6820 hq, quad core 2.7 GHz, 8 MB cache
screen : 15", IGZO 3840x2160
Is it compatible with NX7.5 or later?
This is latest model by DELL, and replaces 4800 ws.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
