Designing P/T podium slab
I have a four story wood-frame structure over a podium (transfer) slab. We first designed it with conventional reinforcement but now my supervisor wants to check if we can come up with a post tensioned slab option.
What softwares are there to design this kind of elevated P/T slab with irregular loading from wood frame above? Please suggest.
Kushal
Kushal
RE: Designing P/T podium slab
Ram Concept
CSI SAFE
RAPT
Ken Bondy has something I think...
Lot's more I'm sure.
Thanks. Have you (or your office) used them personally? In your experience (or your colleague's) do you prefer one over another? (In the sense that which is user friendly, which has less limitations, and which gives better results.)
Very powerful indeed.
Your decision should be based in part on the experience you have in PT design. If a beginner, you should not be using Finite Element design software. This software requires a high level of understanding of and experience in the layout and design of PT floor systems.
I know there will be people who have had no experience in the design of PT or other specialist areas who will say that they have done this successfully. In my opinion they do not understand the concept of being an engineer and the tools that they use and probably do not understand if what they have produced was successful or not. I have seen completely incompetent designs produced in finite element software simply because the designers did not understand both PT design and what the software was doing for them and therefore how to use and interpret it properly (unfortunately one of these collapsed during construction resulting in one death).
No sorry. It was in Dubai several years ago and an area of one slab collapsed when the floor above was being poured. I looked at it for an engineer involved in checking it after the collapse. It was very obvious from the drawings why the collapse occurred. An experienced designer should have seen it straight away but "averaging" of effects in an FEM computer program gave results that said everything was ok.
Too bad there was basically no tendons or reinforcement in either direction over the top of one very un-important column within the punching zone of the column!
Looking at the overall layout for the whole design showed how badly someone can distribute tendons and the computer program still can say all is ok! The layout in the 2 directions was absolutely stupid and very inconsistent.
RAPT I get what you mean. But those kind of people are everywhere, not just in design of PT.
Anyway, I have had introduction to PT during undergrad and I took another course during my Masters. So I am familiar with PT. And I have had courses on Finite element and have used FEM software for other purposes.
But NO, I do not have any real world experience in designing PT or using any FEM to model it. So I guess I am a beginner with good backgrounds. I will definitely get help from an experienced engineer. Meanwhile I have to decide on what software we should be buying. The irregular loading because of wood framed floors above tempt me to get a 3D software.
I have never seen a course on PT that teaches how to approach a design for a complicated slab or how to lay out the PT or even how to model it in FEM (or anywhere else) and interpret the design results correctly. If such a course exists then great, but in my experience the only way to do it is practice and FEM is not the place to start learning and practicing.
I've been mentored by several experienced PT engineers and it was great. In retrospect, however, I didn't pick up anything earth shattering from them that wasn't also available out there in the literature as well. Shrinkage, restraint, balancing, ductility, durability, vibration, deflection, punching shear... The list isn't really much longer than it would be for a steel roof or even a wood deck. PT's neat stuff but you don't have to be bloody Voldemort to pull it off.
Part of being an engineer is being bold enough to apply your knowledge to new technologies that you were previously unfamiliar with. Sometime has to be everybody's first time. Sometime occasionaly has to be the first time. I think that we'd serve OP better by discussing the nuances with him rather than trying to scare him off of using software.
Great, great post. Thank you!
I see an aweful lot of screwed up PT structures. Both on the drawing board and 10+ years after they are built. I recall one structure from the late 90's where the engineer detailed 72 tendons in a band. Our quick hand calc suggested 24. When asked how he arrived at 72 tendons his response was "we did a FEM analysis and that is what was required". The structure was built with 24 tendons per band.
From that time in the late 90's until present, whilst the FEM software has got "better" (aka more user friendly etc) it is my opinion that undergrads finish their degrees with less prestressed concrete experience than when I graduated in the 80's.
If you speak with engineers who are employed by PT companies, oftrn they will share some horror stories with you of PT floor systems that have to be redesigned to make "work".
Inguess reduced design fees for consultants across the globe it is understandable that software plays an important role in cost effective design fees, but only in the hands of experienced users.
Or, if you do, be savvy enough with the fundamental mechanics to adjust the ULS bending strength calculation accordingly.
http://www.nceng.com.au/
"Programming today is a race between software engineers striving to build bigger and better idiot-proof programs, and the Universe trying to produce bigger and better idiots. So far, the Universe is winning."
Agree with rowingengineer too - when I design PT, I usually start with taking a few RAPT (2D) runs to get a feel for how the design is working and my tendon profiles. Then I feed information from the 2D runs into my 3D RAM Concept model.
What I will say however - there are some unique geometry and transfer loading arrangements that are almost impossible to design using hand calcs and 2D runs. This is where 3D models come in handy.
Good saying from one of my seniors: "if it looks wrong, it probably is."
Like your latest footnote! We are not trying to compete with the universe on this one. We write our software for experienced engineers (as you know) and hope the idiots will find it too expensive and too hard to use and buy something cheaper and more idiot friendly!
Kootk,
It is a problem in life (and engineering) that we think we know what we are doing and do not find out what we do not know until it comes back to bite us. In Engineering we hope that happens before the mistake is built when someone who actually knows more than us lets us know and we listen to him, rather than afterwards and we have to pick up the pieces.
Since the advent of more and more complex software, unfortunately we are finding less people able to assist with the better result scenario and many more examples of the humpty dumpty syndrome.
When we leave university we think we know everything. In the next couple of years we find out that we knew nothing when we left university. By the time we get nearer retirement, we realize we still knew stuff all after the first 2 years. By the time we retire, we probably know enough to be good engineers. Unfortunately it is too, late by then!
And no one will listen to the old timers because they are all too old to understand the modern world we now live in.
