Making a faster mild steel cut - Amada
I was cutting 6mm mild steel the other day, and the cut was good enough.
Power was only 1100 and speed was 1500.
This was the maximum speed I could run at this power level.
I figured I could rise the power and gain some more speed, but no matter what i did, I could not get a clean cut with higher speeds.
Cutting parameters are:
Feed rate 1500
Power 1100
Freq 2000
Duty 95
Gas Pressure 0.1
Gas Kind 2
Nozzle gap 1.5
Focus 0.0
Lens 5"
Nozzle 2.00
Attached is one picuture with the clean cut at 1500mm/min
And the other picture with 3 tests at 2500mm/min Power 1500, 1750 and 2000
Feed rate 1500
Power 1100
Freq 2000
Duty 95
Gas Pressure 0.1
Gas Kind 2
Nozzle gap 1.5
Focus 0.0
Lens 5"
Nozzle 2.00
RE: Making a faster mild steel cut - Amada
Power 3000w
Freq 2000Hz
Duty 72%
Gas Pres 0.05
Gap 1.5mm
Lens, 5.0 F/L
Focus 0.0mm
Nozzle 2.0mm
Try that, then bump it up if it's cutting easily.
I have never tried a 1.4mm on a machine with out an adaptive optic. It might work but it also may complicate matters. My opinion, moving the focal point around has the biggest effect on the cut. Usually I move it 0.020". Or 0.5mm +/- untill there is significant improvement. With the 7.5" I change it by 1mm increments.
Food for thought. I have seen a 1500w pulsar cut 1/2" 12mm with a 5" lens. It was beautiful. It just takes time.
