Spring Element Forces in Nastran
One of the confusing aspects to me was the signs of the induced forces in various types of spring elements:
So, a positive spring force is always tension, right?
Well..... I found out not really, so i kind of summarized a few things here: http://www.stressebook.com/spring-element-forces/
Would love to know what you guys think and if I could add some more value to the post based on your comments. You can comment here or under the post, I'd love to hear from ya..
Cheers..
Cheers..
Aerospace Stress Analysis and FEA Courses
Stressing Stresslessly!
RE: Spring Element Forces in Nastran
For a CELAS then +ve load = tension
Did some simple testing and found that CROD/CVISC (axial spring option in the CBUSH dialog box in FEMAP)is the only one that is consistent in terms of +ve tension /-ve compression.
However it is important to keep in mind it provides stiffness in all three directions with one axial stiffness value.
You can see in the table below that the element connectivity and load type (force, displacement) and direction all influence the signs in the DOF Spring and CBUSH.
Same applies to "net" displacement load.
