Automatically switching Display States when selecting Exploded Views
I have an assembly with several exploded views, each exploded view corresponds to a different display state. Every time I want to view a particular exploded view I have to manually select the correct display state. Is there a way for assign a display state automatically to each exploded view?
To simplify things I've given the matching exploded views and display states the same name so I know which goes with which.
Thank you!
RE: Automatically switching Display States when selecting Exploded Views
I'll assume by the lack of responses this is not possible.
Thank you CorBlimeyLimey. That helped, somewhat.
I learned that it works if you are trying to link a display state exclusively with a specific configuration. I was trying to link each display state with specific exploded views, and all my exploded views are within the same configuration. So in the future I may have to create a configuration for each exploded view.
And by the way, I recently upgraded to SolidWorks 2015 and the option "Link Display States to Configurations" has been moved to the Properties menu of each display state;
Right-button mouse click on the display state name > Properties > Advanced Options.
