Shaded View Plotting undesired results
RE: Shaded View Plotting undesired results
Have you tried plotting a shaded image to the Hp1170 from a different source other than NX ?
Thanks Jerry
NX is the only CAD software I have available.
What would you recommend?
In the plot dialog -> settings -> drawing sheet, what "image resolution" setting did you use?
If you used "draft" or "low", try bumping it up to "medium" or "high".
www.nxjournaling.com
Cowski, Thanks!
This setting was already on High, but by changing it to Draft the graphics print correctly.
