Amada FO 3015 Aluminum cutting
I just was looking for some help with cutting .060 Aluminum. We have tried using the shop gas and nitrogen neither has been successful. Usually I can cut one or two good parts then they start to become "welded" in to the sheet. It seems as though it only happens the final inch before reconnecting with the pierce. What could be causing this problem?? I have been messing with the laser for days with nothing to show for it.
RE: Amada FO 3015 Aluminum cutting
Cut Conditions
5" lens
Gas kind 4
Gas press .6 to .7
Nozzle 3.0
Nozzle gap .02
Focus -.02
Set on Clean cut
Pierce conditions
power 2000 - 4000
Freq 100
Duty 100
Gas kind 4
Nozzle gap .15
You may have a cooling issue, or a stressed optic somewhere (lens would be first one to try). If it's not the lens, then it could be the output coupler inside the resonator (best to call service for that one). How many hours do you have since the last maintenance on the resonator?
