TECTUM Roof Panels or similar product - lateral support for structural steel
I am looking at a Circa 1960's building with TECTUM or something similar roof panels, and wondering if this provides lateral support to perimeter roof beams. I don't think so, as the bulb tees supporting the panels look real small (from the little that is visible), but would like to hear from others. Span of the panels is 10 ft.
RE: TECTUM Roof Panels or similar product - lateral support for structural steel
Dave
Thaidavid
The bulb tees do provide lateral bracing, the Tectum (or similar) panels do not.
Some modern versions of the system have diaphragm capacity clearly: Link
and finally CMU walls and roof near the perimeter leak (but not thru the roof membrane, its perfect).
And maybe its not actually Tectum, but it looks likes it.
The whole purpose of this project is to deal with the leaks.
The problem is if the existing steel beam is not laterally supported, it is undersized, (if laterally supported then OK) and getting the larger steel section in its place may not work because flanges get a little wider.
Mike McCann, PE, SE (WA)
Kinda the flip side of older engineers losing their memory.
