Column buckling
Column buckling
Hello friends,
i have a question about column buckling.
Assume a circular stiffened plate which is simply supported along its edge. a uniform lateral distributed pressure acts on the plate.
The stiffeners are welded to the top of the plate.(I have attached the picture). some detail information:
Diameter of circular plate =1000 mm
Pressure :15000 Pa
Thickness of plate = 6 mm
stiffener size : 50 mm * 10 mm
Which kind of buckling can happen for the stiffeners? any probability for column buckling?
Some one has asked me to check for column buckling but i believe the only probability for buckling is LTB (Lateral-torsional buckling)
I will appreciate any help.
Pressure :15000 Pa
RE: Column buckling
The lateral torsional buckling would be resisted by the connection of the stiffener to the circular plate I would think.
The local buckling would be avoided by having a thick enough stiffener plate.
RE: Column buckling
As discussed before, it would be better to place the stiffeners on the unloaded side of the plate because the compression edge would then be laterally braced by the circular plate.
If stiffeners are to be welded on the loaded side, lateral torsional buckling could be checked by applying principles given in the code. As a suggestion, you could calculate the maximum compression C in each stiffener, then ensure that the circular plate is capable of resisting a moment equal to 5% of C.e where e is the eccentricity of the centroid of compression from the centerline of plate.
BA
RE: Column buckling
from your explanation, i found that the probability of column buckling is zero.
for column buckling, axial load is necessary. am i true?
THX.
RE: Column buckling
RE: Column buckling
i talked to my colleague. i think he made a mistake. he is referring to standard API Bulletin 2V. he told me that one of the important parameter that affects buckling of stiffener is slenderness ratio. he concluded that since LTB (lateral-torsional buckling) and LB (Local Buckling) doesn't consider this important parameter, column buckling should be checked!...
