Sour oil trap operation?
Hi, Could someone help me as I am trying to figure out how does a sour oil trap of a centrifugal compressor work. The only information I have is that a sour oil trap basically removes the process gas trapped inside the seal oil and vent it (please correct me if I am wrong) and that it contains a float and orifice etc. What I really want to know is that how do these components come together to separate process gas from oil and what is the purpose of a blow down valve in the trap??
RE: Sour oil trap operation?
In some of our pots there are float mechanisms that open automatically on high level to drain the pot to some suitable system. The contaminated seal pots could be said to allow residence time with reduced velocity to allow the oil and gas to separate. Depending on where the oil is discharged, this could be important. This separation occurs at low velocity by virtue of gravity. I don’t know what you are referring to as a blowdown valve. Is it a manual drain for draining the pot to a different destination?
Johnny Pellin
Also, notice that Johnny's description talks about "contaminated seal oil traps", not "Sour Oil Traps". I've often seen them called "sour oil traps" in plants that process sour gas, I think that is to pound home that opening them in that service is dangerous. Both terms refer to the same device (except maybe materials of construction).
David Simpson, PE
MuleShoe Engineering
In questions of science, the authority of a thousand is not worth the humble reasoning of a single individual. Galileo Galilei, Italian Physicist
