Packing Identical Items in Structure manger
Same revision and item names part number are not packing in structure manger like UG-NX. the preference is as shown below.
Preference name: PSEAutoPackPref. Accepts a logical 0 or 1 as a value.
Default setting: 1 (pack identical occurrences on a single structure line).
RE: Packing Identical Items in Structure manger
Check you sequence number. These will need to be the same also to pack similar objects.
