Creating edge and node sets in Abaqus using Python
Hi guys
I have not much experience in Python scripting for Abaqus. I am importing an step file from catia to Abaqus. I want to create edge and node sets for applying boundary conditions. I came across an "findat" option to do it.. But i am not successful with it.
Is there any other option of selecting specific nodes at specific edges to form a set in abaqus?
assembly = mdb.models['Upper_Rail'].rootAssembly
assembly.Set(edges=assembly.instances['al_part'].edges.findAt(((308.044891, -747.636108, 669.81366),),), name='fixed_edge')
assembly.Set(name='fixed_nodes', nodes=assembly.sets['fixed_edge'].nodes)
The coordinates is the starting point of the edge which i need to select.
i get an error
Warning: findAt could not find a geometric entity at (308.044891, -747.636108, 669.81366)
REg
Gokul
i get an error
REg
Gokul
RE: Creating edge and node sets in Abaqus using Python
If your coordinates are not precise enough, you could use getClosest().
I did this the place i want to create the sets are the exact one. But how do i say abaqus to select the edge which starts from this coordinate?
i = mdb.models['Model-1'].rootAssembly.instances['Part-1-1']
print i.faces.findAt((1,0,0),)
({'featureName': 'Part-1-1', 'index': 5, 'instanceName': 'Part-1-1', 'isReferenceRep': False, 'pointOn': ((9.166667, -4.166667, 0.0),)})
And creating a set:
x=i.faces.findAt((1,0,0),)
edges1 =i.edges[x.index:x.index+1]
mdb.models['Model-1'].rootAssembly.Set(edges=edges1, name='Set-1')
i = a.instances['Part-1-1']
x = i.edges.findAt((1,0,0),)
a.Set(edges=edges1, name='Edge-Set-1')
Still it doesnt work fine with this "findat" command. Especially this line
when i give my coordinates it doesnt have any geometric entity in it.. I am trying to find it using an "getbyboundingbox" command.
Any idea on how to select the faces using python..? have tried it with many options not working out though..
- if you know exactly the location, then you can use findAt()
- if you know an approximate location, you could use getClosest()
- searching by a bounding box or sphere is similar
- or you know that this face is the outer/innermost face of the structure in a direction, then you could cycle through all faces and check each pointOn() information
I can create an example script, but not without more information of your specific problem. So if you're interested, upload a CAE file with a part/instance and mark the face (with a set, i.e.) you would like to access via Python. Then I could script how to do that.
PS: And let me know if it should be done at part or assembly level and what information of that face you have in advance.
Thanks for ur help.. Actually i am using a .stp file imported from catia. So i will upload the .stp file to you. Because i am not sure whether i can use all the features of Python with imported parts. I hope u can just create a surface using python . Thanks a lot mate. I have also attached a picture showing the surface i want to select.
Reg
Gokul
And also i am finding the coordinates of the points in the part by writing a input file prior to the analysis, so that i can get the coordinates at certain locations. Is there any way to also see what informations that can be got just from the part imported from Catia.
When i use the keywrods like, getnodes(), getedges(), getfaces() i am not able to see anything. How to see in prior what infos i have in my part?
But with the coordinates from your first post you'll not get the face you want. The other face seems to be closer.
#your coordinates = 308.044891, -747.636108, 669.81366
#geometry vertex between faces = 308.044876,-747.636108,669.81366
In general it is not a good idea to use a coordinate where it is not clear which face is the closest.
CODE
Setbyboolean helped me...
Thanks..
Is it possible to give a raw input to abaqus from python script.. I would like run my script having a raw input command to choose the material of the users choice. I am having a array of material values and i want abaqus to prompt whenever i run my script for materials
Think i have put it clearly to you.
