Team file management for students?
As a student I'm about to embark on my first larger scale project, which will require coordination of editing multiple parts/products within a team.
Does anyone have any advice on good practice for this?
Also, as we have no infrastructure, I was hoping to be able to use Dropbox to host files. Does anyone know if this is possible? Or will the continual updating muck up products?
Cheers,
J
Cheers,
J
RE: Team file management for students?
As advice, start with SAM (space allocation mockup) for the concept and first modelling of the components, assign part numbers for your components (using a collaborative excel type file), create some kind of revision system, do not allow to all the right to make changes in the master assembly.
If you will use github or grabdcad, post a link.
