WindowsXP and HEC-RAS
Does anyone know if HEC-RAS and or EPANet will run under WindowsXP.  Both appear to require DOS but I am not certain of this.
Russ Faust
Salem, OR, USA
RE: WindowsXP and HEC-RAS
Hi, Russ:
As far as I know, HecRas runs on the windows environment. I don't know about the other software.
Robert.
Hi Russ:
I do not know about EPANET, but I do know that HEC-RAS 2.0 and 3.0 do work in windows 95, and above.
Francis A Smith, PE
Denton, Texas
Russ -
I have had success running Hec-Ras on Windows XP.  I've never heard of the EPAnet. Good luck...
Kelsy Ausland
Civil Engineer, EIT
Medford, OR
Thank you to all who replied to my post.  EPAnet is a public domain program for solving pipe network flows and pressures derived, I believe, from KYPipes.
Russ Faust
I have used Hec-Ras on Windows XP.
