changing vertical dimension of sketch
Hello
I want a dialog box where a user can change the vertical dimension of a part file. So I recorded a journal of changing the vertical dimension, and I also created a dialog box with BlockUI. But I dont understand the journal file.
In the journal I changed the vertical dimension in 2000, I can find the number "2000" two times in the journal-file.
So I though I could just change "2000" in ExpressionBlock.Value (the inputfield is of type expression
But it's not that simple :)
Hope someone can help me how to use the journal file.
