SHELL COURSE HEIGHT FOR TANKS
Good Afternoon srs
does API 650 provide for the shell course a minimun height or maximum for the shell courses??
for example can we design a tank of 8m in height with 4 courses of 2m of height or with 3 courses of 2.6 m?Obviously the calculation must be verified...Ok then we can talk of good practice...etc etc..but what does the code provide?
Let me know please
regards
RE: SHELL COURSE HEIGHT FOR TANKS
See 5.6.1.2 and S.3.2.1.2
72 inch [1800mm] or 48 inches [1200mm] for stainless steel
Ok...so we have only a minimum widht..
thank you.
regards
maximums are driven by plate availability and if the field crew can handle it efficiently
here in saudi arabia all tanks courses used are 2 m width not more than 2
We use a lot of 3048mm plate in the USA
