Rename CATIA V5 Product and Parts
Hi to everyone.
I've a problem, i need to rename an assembly (and all sub-assembly and parts) changing only a the first part of the name.
EX :
all my files start with a code of 7 numbers, i need to change only this 7 numbers in all files
1234567_aaa.catproduct
1234567_bbb_catpart
1234567_ccc_catproduct
1234567_ddd_catpart
must become
7654321_aaa.catproduct
7654321_bbb_catpart
7654321_ccc_catproduct
7654321_ddd_catpart
There's a way (macro ??) to speed up the saving of these files ?
Thank you !
RE: Rename CATIA V5 Product and Parts
yes you can make a macro. That do the job easy.
Eric N.
If you only mean the operating system filenames need changed, you can even just use the good old DOS window.
You would still need to manually edit the part and product properties inside Catia though.
I use DOS to do somethings in milliseconds that Windows can't do at all.
It's class.
Here's the procedure, but be careful. If you don't know what you're doing you can wipe out your PC in a nanosecond.
Go to the START menu
Select Run
Type in command
A black DOS window should appear.
You then type in the following command, but obviously editing it to suit where you have stored the files.
My example will have the files located a few folders deep from the root of the hard drive C
I purposely use only maximum 8 character folder names since DOS only allowed 8 characters.
(There is a way to use long names but it involves more complicated filename typing using squiggles etc).
REN C:\TESTFOLD\MYFILES\1234567*.* 7654321*.*
That will do them all in one hit.
Just note there is a space between 1234567*.* and 7654321*.*
Just type EXIT when you want to leave the DOS window
You can also freely use the ? wildcard to represent a single character, as opposed to the * which represents any group of characters.
I'm amazed Windows has no features like this, or if it has, I have never heard of them.
P.S. If in doubt at all what you're doing, practice on a trash PC that you don't mind eliminating smile
beware of catia links management if you rename outside of catia process
Eric N.
@itsmyjob
I tried to make a macro, but i'm not very good with these kind of programming.
Could someone help me ?
@MRSSPOCK @itsmyjob
I have many link between files, i must do the process IN catia, I need to mantain those links
Thanks to everyone !
We need to know more about your file structure. Are the parts and products all inside of a product?
Can the script be in VBA or CATScript?
If you can use VBA (alt+f11 to open the VBA editor) you can probably use something like the following. I did not test it, so I would try it on a test structure. There may be other properties you want to rename...this is just an idea based on what little I know about the issue. It doesn't account for all the error states of a part number.
CODE --> VBA
Sub CATMain()
	Dim oDocument as Document
	Set oDocument = Catia.activedocument
	Dim oRootProduct as product
	Dim oProduct as product
	Dim oSelection as Selection
	Set oSelection = oDocument.selection
	Dim oSelectionLB
	Set oSelectionLB = oSelection
	Dim sOldNumber as String
	Dim sNewNumber as String
	Dim aSelectionFilter(0) = "Product"
	If TypeName (oDocument) = "Product" then
		set oRootProduct = oDocument.Product
		oSelection.Clear
		sMessage = "Select a part to renumber"
		MsgBox sMessage
		oSelectionLB.SelectElement2 aSelectionFilter, sMessage, True
		If oSelection.Count = 0 then
			Msgbox "Macro Canceled by user"
			exit sub
		Else
			sOldNumber = oSelection.Item(1).Value.Nomenclature
			oSelection.Clear
			sNewNumber = "A"
			i=0
			Do until Len(sNewNumber) = 7 and IsNumeric(sNewNumber) = True and Val(sNewNumber) = Int(sNewNumber)
				sNewNumber = InputBox("Type new 7 digit number)
				i=i+1
				If i = 5 then
					Msgbox "You can only enter a 7 digit number, exit macro"
					end sub
				end if
			Loop
			For i=1 to oRootProduct.products.Count
				Set oProduct = oRootProduct.Products.Item(i)
				If oProduct.PartNumber = sOldNumber then
					oProduct.Nomenclature = replace(oProduct.Nomenclature, sOldNumber, sNewNumber)
					oProduct.PartNumber = replace(oProduct.PartNumber, sOldNumber, sNewNumber)
					oProduct.Name = replace(oProduct.name, sOldNumber, sNewNumber)
				end if
			Next
		End if
	Else
		MsgBox "Product not loaded, exit macro"
		end sub
	End if
End Sub
@lardman363
Yes, i can use the VBA
All inside the product there are many parts and products, it's a very big assembly so i need a macro that rename all the files in my assembly
1234567_bbb_catpart
1234567_ddd_catpart
1234567_eee_catproduct
1234567_fff_catpart
1234567_ggg_catproduct
1234567_hhh_catpart
1234567_iii_catpart
This is an example where all "1234567" must renamed in "7654321" without changing the 3 letters after the names
Load your assembly in CATIA and run this from VBA:
CODE --> VBA
Sub CATMain()
		oSelection.Clear
		sOldNumber = Left(oRootProduct.Nomenclature,7)
		sNewNumber = "A"
		i=0
			i=i+1
			If i = 5 then
				exit sub
			end if
		Loop
		oSelection.Clear
		oSelection.Search ("type=Product,all")
		For i=1 to oSelection.Count
			Set oProduct = oSelection.Item(i).Value
			If instr(oProduct.PartNumber, sOldNumber) <> 0 then
			end if
		Next
		oSelection.Clear
		MsgBox "Macro Complete"
	Else
		exit sub
	End if
End Sub
@lardman363
I run your script on CATIA in the "first" product, but it doesn't work
I see only the message "product not loaded, exit macro" .. Why ?
it seems that does not recognize the product ..
thank you so much
Sorry, it should say
If TypeName (oDocument) = "ProductDocument" then
ok ..
Now the problem is in the line
"Do until Len(sNewNumber) = 7 and IsNumeric(sNewNumber) = True and Val(sNewNumber) = Int(sNewNumber)"
What is the error?
Since it is looking for a number, maybe use
CODE --> vba
sNewNumber = "1"
@lardman363
The error is "type Mismatch"
and is in the line "Do until Len(sNewNumber) = 7 and IsNumeric(sNewNumber) = True and Val(sNewNumber) = Int(sNewNumber)"
I try to change the value of sNewNumber from "A" to "1", but it doestn't work
Thank You
Type mismatch means a variable is one type but the code is expecting another. The only variable in that line is sNewNumber, it is a string. Int is looking for a number.
CODE --> vba
Do until Len(sNewNumber) = 7 and IsNumeric(sNewNumber) = True and Val(sNewNumber) = Int(Val(sNewNumber))
Perfect !
Now the macro run, but it doesn't rename, right ?
Use below macro in CATVba....
for using this macro, follow below steps
1) first create new assembly from old assembly by using File->new from
2) run this macro...
3) In first input box , "enter string to be replaced" ..... as in your case it is "1234567"
4) In second input box, "enter replaced string".............. as in your case it is "7654321"
5) Use file save management to save all child parts and assembly at new location
Sub CATMain()
Dim root As Document
Set root = CATIA.ActiveDocument
Dim docs As Documents
Set docs = CATIA.Documents
If (root.Path <> "") Then
MsgBox "Please Use This macro on Unsaved Product"
Exit Sub
End If
If (TypeName(root) <> "ProductDocument") Then
MsgBox "Please open Assembly File"
Exit Sub
End If
Dim FstInp, SndInp As String
FstInp = InputBox("Please Enter String to be Replaced")
SndInp = InputBox("Please Enter String to Replace")
If FstInp <> "" And SndInp <> "" Then
root.Product.PartNumber = Replace(LCase(root.Product.PartNumber), LCase(FstInp), LCase(SndInp))
Call ALLTREE(root, FstInp, SndInp) ' callin procedure
Else
MsgBox "Input not reached correctly"
Exit Sub
End If
End Sub
Sub ALLTREE(Froot As ProductDocument, FstStr, SndStr)
Dim objFPrd As Product
Set objFPrd = Froot.Product
Dim objFPrds As Products
Set objFPrds = objFPrd.Products
For i = 1 To objFPrds.Count
Dim objFIns As Product
Set objFIns = objFPrds.Item(i)
objFIns.Name = Replace(LCase(objFIns.Name), LCase(FstStr), LCase(SndStr))
objFIns.PartNumber = Replace(LCase(objFIns.PartNumber), LCase(FstStr), LCase(SndStr))
If (TypeName(objFIns.ReferenceProduct.Parent) = "ProductDocument") Then
Call ALLTREE(objFIns.ReferenceProduct.Parent, FstStr, SndStr) 'if instance is product then calling the procedure
End If
Next
End Sub
Hi
This code worke But in replace "ABC" & "abc" is same!!!!
Please edite your code.
Very Thanks.
this forum is a good place to get some help, not a place where to get work for free.
if you want to contribute and bring better stuff to the community I suggest you do your work and share it.
so pretty please, do some work, and thanks for sharing.
(sorry if I sound rude, I did not finish my morning coffee yet)
Eric N.
I completely agree with you...
______
Alex ,
Hello SachinTata and Everyone
Thanks to forum member
I mean,
Change the name of Part & Product that start by Non-Number:
ABC****=Dce***
but this code :
ABC*** => dce***
Pleas help me for Non-Numbers in name
Best Regards
got it itsmyjob
@3DPLM
remove LCase from the replace string and use vbTextCompare as argument, then you will get the desired result
check below lines
objFIns.Name = Replace(objFIns.Name, FstStr, SndStr, , , vbTextCompare)
objFIns.PartNumber = Replace(objFIns.PartNumber, FstStr, SndStr, , , vbTextCompare)
