Importing and modifying foreign part
Hello all,
I am currently trying to modify a part supplied by our manufacturer.
I need to remove the slots in the front of the part, before I can make my own modifications. I have tried a few ways including synchronous modelling and also surfacing which 'seems' to be where I'm having the most luck.
I realise that a have to close/sew a surface for it to auto turn into a solid but I can't seem to think of a way to close the surface I'm working with. I also know that my surfaces must be as accurate as possible and I have also tried to do this.
I am most likely going about this the difficult way and if there is an easier option please let me know (as well as helping with my current prediciment - Id like to learn how to fix the problem).
I have attached the .prt
Thank you for your help in advance.
RE: Importing and modifying foreign part
There is no attached part.
Please try again.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Digital Factory
Cypress, CA
Siemens PLM:
UG/NX Museum:
hi,
Please check with examine geometry command for finding out the open boundaries.
Mathi K
