Buoy uplift calculation
Hello all,
This is my first post !
I am facing a forces/uplift calculation issue and I am seeks for advice.
I would like to calculate the required buoy uplift to lift a section of 40 m of pipe from the seabed. I attached a drawing for clarity. The values are not exact, I am looking for a general formula / approach to calculate uplift for different pipe properties and tie in heights. My first impression was that the buoy uplift is equal to the total weight of the lifted pipe, but it seems that this is incorrect. Can you please help ?
Many thanks.
RE: Buoy uplift calculation
Have a look at the Wikipedia article on "Catenary" for a starting point.
A.
Are you going to excavate so that there is no overburden?
If so then it is a simple statics problem.
If the pipe is not free and clear of the seafloor then the forces can be very much higher.
